Some things are not magically come out for custom renderers. It needs to be integrated in C4D's way by using their sdk. I don't know how to add this.momade wrote:I might have asked this before dear aoktar.
Why doesn't the Render Queue shoe the process bar when rendering with Octane Render?
Version 3.08-RC1.1
@aoktar
Hi
The Lut Strength slider is missing in the plugin.
Also, considering how many HW/Driver issues people are having, I think it would be useful to have the 'Max. tonemap interval' parameter available in the plugin just in case. Just like it is in the Standalone. I also noticed that the default value is different in the plugin than the one in the Standalone. Maybe someone might have to adjust that parameter but it's not available in the plugin.
Milan
Hi
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
So far I found this release solid rock!
I'm still finding inconsitency issues among the shaders preview windows resizing: they behave differently along MIX, Uber, Metal, Diffuse, Toon, etc. concerning pixelation, sphere framing, stretching, sometimes is pixelated, sometimes are ok... I found the MIX material to be the only to nicely previewed in every aspect mentioned.... the others beahave randomly well...
I'm uploading this small .gif, perhaps it may help improving this, Aoktar!
Cheers!
Cheers!
Octane User since V1 Beta
aoktar wrote:Some things are not magically come out for custom renderers. It needs to be integrated in C4D's way by using their sdk. I don't know how to add this.momade wrote:I might have asked this before dear aoktar.
Don't worry ist a really really minor detail. I fully understand.
Thanks, got both sheen and anisotropy. As far as i know there is no way to make coated material?aoktar wrote:You need to change brdf type and add some glossines for anisotropy.anklove wrote:I dont get how does new sheen and anisotropy work in the new glossy material?
i7 10700k | Win 10 64 bit | RTX 3090
It seems that the latest update has some issues with phong angles and displacements maybe? The textures work on flat planes, but when I create a landscape object and apply the texture I get the outcome in the attached screenshot. I am using a material that I've used many times in the past. Attached is a screen shot of the outcome on the newest 3.08-RC1.1 version.
I'm sure you probably have already had people report this, but wanted to put it out there as well.
Thanks for all you do Aoktar!
- Stuz0r
- Stuz0r
What you problaby want to do could be achieved with MIX or Uber material.anklove wrote:Thanks, got both sheen and anisotropy. As far as i know there is no way to make coated material?aoktar wrote:You need to change brdf type and add some glossines for anisotropy.anklove wrote:I dont get how does new sheen and anisotropy work in the new glossy material?
Cheers!
No limit should be 12 now and new uber is much more improved for usage.Guy_frog wrote:Hi Ahmet, could you confirm that for version 3.08 RC1.1 the uber material is still limited to 3 sub materials?
EDIT: ok thanks, solved: it works well for me beyond the 3rd sub material. It came from the side node that I tried to use mix with texture in the input.aoktar wrote:No limit should be 12 now and new uber is much more improved for usage.
I take this opportunity to expose my pb with the uber material: I have a label stuck on the back of a transparent bottle and so this label is visible on both sides with a different texture on each side. For the first side of this label, the label alpha texture in the input / mix of the submaterial is ok, but then, with the next sub-material how can I get the opposite side knowing that I have only one input to put the side node and the label alpha texture?
