OBJ files - default material type
Jorgensen
as it seems, that the plugin for sketchup never gets stabile (at least for me), i have to use the standalone version.
and one thing that frustrate me is, that the default material for obj files are glossy, so i need to select every single material and change them to diffuse.
would it be possible to add an default material option for obj import in the settings - like it's now added in the plugin for sketchup?
ps. i like the standalone verion :-) (apart from this material issue and the face that i can't lock a camera position - but that's an other story.)
thanks
jorgensen
paride4331
Hi Jorgensen,
can not sketchUp export your scene to .orbx?
Jorgensen
It might do - but Octane crashes my Sketchup.
And as i remember it, Octane does not let me select witch objects i would like to export.
I might do it all wrong, butit works fine for me, apart from the glossy material.
jorgensen
Hi jorgensen,
in Standalone Preferences/Import/OBJ you can specify some import preferences for obj materials from the .mtl file:
ciao Beppe
Jorgensen
a¤%#¤%?=)#¤%?= )#¤%=% doooohhhh - i missed the scrollbar - so i just saw the top of the iceberg :-)
thanks
beppe
