Proxy dosent show on render
Forums: Proxy dosent show on render
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby kzaremba » Fri Mar 09, 2018 1:10 pm
kzaremba Fri Mar 09, 2018 1:10 pm
I was trying to make some proxies according to this tut:
https://www.youtube.com/watch?v=OEQfUOBAdS0
Attached proxied dosent apper on render - archicad object desappers. Proxy menue dosn't show file path and scale is ocward even if I change it its comming back to same state - see attachemnt. Dose anyone have clue what went wrong ?
I got error in cuda log during secen loading:
relative path with root given. Root '' will be ignored.
kzaremba
Re: Proxy dosent show on render
Postby face_off » Fri Mar 09, 2018 9:38 pm
face_off Fri Mar 09, 2018 9:38 pm
Hi, I have not seen these error before.
Could you pls send me the proxy file you are using and a simple .pla which reproduces that error with that proxy, and I will take a closer look.
Postby kzaremba » Sat Mar 10, 2018 7:28 pm
kzaremba Sat Mar 10, 2018 7:28 pm
Thank you for quick respond.
When I was preparing files for you it turned out that everything works fine. I'm not sure what was the reason when I have same I will save file.
I have one question are proxies also savable like materials. So whenever I put same tree object it will be an override by same proxy?
By the way, I'm testing Octane in Archicad for short time. Until now speed, quality and stability are amazing... Great job!
kzaremba
Postby Jasonr » Fri Mar 30, 2018 6:57 am
Jasonr Fri Mar 30, 2018 6:57 am
I noticed the same thing two days ago.
When the model is loaded for the first time from the plugin all the proxies at the proxy tab show a scale of 0.0001 and the file path is empty.!!!!
The objects looks normal.
I have to refresh the scene for the proxies to appear correctly at the settings tab.
It looks like the first loading misses something.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Postby face_off » Wed Apr 04, 2018 3:49 am
face_off Wed Apr 04, 2018 3:49 am
If you have a sample scene and proxy which reproduces this issue, pls send it to me and I will take a closer look.
Postby rappet » Wed May 29, 2019 11:54 am
rappet Wed May 29, 2019 11:54 am
Yes, I am having the same problem.
After selecting a proxy it does not appear in the window and therefor not in the render Window if it has nver been selected,
but hte archicad used for proxy is noit shown in the Render Port either.
After refresh the scene the proxies still do not appear correctly at the settings tab.
No error found in the cuda log. (?)
Running OctaneRender 4.02.1.91
Though, closing the Plugin and re open the plugin the proxies do appear as selected in the first place!
greetz,
rappet
Postby face_off » Thu May 30, 2019 9:15 am
face_off Thu May 30, 2019 9:15 am
I just tested this on the latest version of the plugin, and could not reproduce the error. Can someone please confirm it happens on the latest version, and if so, the exact steps I need to take to reproduce the error.
Return to Graphisoft ArchiCAD
Thu May 23, 2024 6:43 pm [ UTC ]
