active layer per render layer
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Issa
Hi, last update works fine but i need different active layer per render layer please
J.C
The first list on the screenshot you've posted refers to Cycles specific workflow. It does not work with Octane. This should be removed or greyed out by developers.
System – Windows 11
Issa
@J.C
I can have different active layer per render target from Stand alone version.
J.C
Issa wrote:@J.C
As far as I know in Blender plugin we have one Render target. If you want another target you can create a new scene with same objects.
What you've noticed would be very useful. I wish developers would add such functionality in the future.
System – Windows 11
DrawFun
Hi issa and J.C, thanks for your report and advice. The cycle render layer will be hide in 15.1.
pegot
Hi. I sometimes make extensive use of Blender's layer system rather than Octane's render passes. See attached screen shot. This would break my project if Blender layers were hidden in Octane Blender. Maybe I am not understanding and this is a separate issue your discussing? But as you can see from my screenshot Blender layers work fine in Blender Octane plugin.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
DrawFun
Hi pegot,
Thanks for your report.
We will investigate further about the cycle render layer in the next release. But for the coming 15.1(already in the final stage of test-release pipeline), we will keep it as hide by default.
You can turn it on as following if you want.
1. open "properties_render_layer.py" under "[BLENDER_FOLDER]\2.79\scripts\startup\bl_ui", e.g. for me, it is "C:\Program Files\BlenderOctane15.1\2.79\scripts\startup\bl_ui";
2. remove 62-64 lines and save
        if rd.engine == 'octane':
            layout.label("Not available in the Octane Engine")
            return
Please backup the file before modifications. Sorry for the inconvenience.
Return to “Bug Reports”
