Mineral Reign Materials and Texture Set ..
Forums: Mineral Reign Materials and Texture Set ..
Re: Mineral Reign Materials and Texture Set ..
Postby rmara » Wed Feb 28, 2018 8:52 am
rmara Wed Feb 28, 2018 8:52 am
Two more materials added in the collection
Granite & Sand in 10k.
Dark granit in 9k.
More to come...
rmara
Postby rmara » Fri Mar 02, 2018 9:21 am
rmara Fri Mar 02, 2018 9:21 am
Here are sneak previews of the displacement maps only ,
all other channels disabled.
Displacement maps are 8192 x 8192
rmara
Postby rmara » Sat Mar 03, 2018 12:18 pm
rmara Sat Mar 03, 2018 12:18 pm
Some more renders of the displacement maps only...
rmara
Postby rmara » Sun Mar 04, 2018 8:03 pm
rmara Sun Mar 04, 2018 8:03 pm
Two more textures added in the library...
Mossy granites in 7600 x 6700 and 11300 x 7800
with diffuse, specular, roughness, bump and displacement maps...
More to come...
rmara
Postby nildoe » Tue Mar 20, 2018 4:29 pm
nildoe Tue Mar 20, 2018 4:29 pm
please tell me your gonna make these compatible with other DCC, I use 3dsmax and your shaders are AWESOME! any chance for an ORBX of them? this way we could use in max as well..
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe
Postby rmara » Tue Mar 20, 2018 6:03 pm
rmara Tue Mar 20, 2018 6:03 pm
Hi Nildos
Thank you very much for your encouragements !
I'll try to make it available through the orbx format so all the octane users of all plateform can enjoy it ! and this within the very first release.
but its' the first time i'm preparing such a big library for the community so I'm learning a lot on the way.
Also I'm still in the process of refining the textures so far.
It has been a hard work that was a little longer than expected
( considering that 'I'm actually a comic's artists who must still deliver his work to the publishers and artists every other day too. ;) )
But yes I'll try to make as much cross plateform as possible.
And also the vast majority of texture can be plugged into each channels in octane a is
This is why I kept the node editor as simple as possible,
with just the textures and and color correction node
so users can just tweak the contrast, power or gamma
but most of the time my settings are set to default
and I try to do most of my adjustements on the tiff files themselves.
So ultimatley these could even be used with other renderers like vray or Arnold too.
Only in this collection I will provide the Octane material library for our community to enjoy it more easily.
here is an exemple fo the simplicity of the nodes of most materials :
Mineral Reign node example
rmara
Postby rmara » Wed Mar 21, 2018 5:00 pm
rmara Wed Mar 21, 2018 5:00 pm
If you guys agree to test,
i will send a orbx test file on this thread so you can tell me
if the materials import correctly in maya, 3D studio max and others octane plugins...
rmara
Postby rmara » Tue Mar 27, 2018 8:26 pm
rmara Tue Mar 27, 2018 8:26 pm
Following this Gumroad link (updated),
you can download a free selection of 8 materials and 40 texture maps
as a sneak preview to the final collection...
I included a .c4d file and a .orbx file too...
The textures have been downsized to 1024 x1024
but as you already know, the collection will have maps from 2k to 4k.
Just let me now what you think
and also if you had some succes using them in other softwares than Cinema4D through the .orbx format...
https://gum.co/mineralreignpreview
rmara
Postby rmara » Thu Mar 29, 2018 9:36 pm
rmara Thu Mar 29, 2018 9:36 pm
And here is finally the first release of the Mineral reign collection
it contains 64 mIneral materials
- With 340 texture, Diffuse, Specular, roughness, bump, Displacement and normals maps in tiff format.
- A .c4d file with the materials setting for c4d Octane.
- .Orbx files containing all the materials settings and maps to be use with Octane Standalone or any other 3D app with Octane as renderer.
it's a 15 go material and texture collection.
I hope you will have fun using these materials.
If you happen to do some great art with the materials, you can post it here or mail it to me...
I'd be glad to discover how you enjoyed them and benefited from them.
you can get the collection here :
https://gumroad.com/l/mineralreignfull
by using the promotional code "otoy"
you can get the full collection with an offer of 10% on the full price for a month.
NEW UPDATE : Gumroad has fixe the problem and the offer code is now usable...
rmara
Postby rmara » Fri Mar 30, 2018 1:52 pm
rmara Fri Mar 30, 2018 1:52 pm
Everything seems to be back to normal at Gumroad now ...
So you should be able to use the offer code giving you 10 % off for the month of April...
offer code is "otoy"
rmara
PreviousNext
Return to Works In Progress
Tue Feb 18, 2020 3:45 pm [ UTC ]
