Maximum Tonemap Interval
J.C
What does it do in Imager settings? The manual only says:
"Maximum interval between tonemaps in seconds."
System – Windows 11
BK
J.C wrote:What does it do in Imager settings? The manual only says:
Hi JC,
It's the maximum time intervals (in Sec) between two tonemapped images as shown in the tooltip help.
cheers
Kind Regards
bk3d
pegot
I don't understand this either. In what use case or scenario would one change this setting, and to what effect? Can any one give a concrete example?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
BK
pegot wrote:I don't understand this either. In what use case or scenario would one change this setting, and to what effect? Can any one give a concrete example?
Octane Render works in a linear curve mode on the camera imager like a post processing effect. So, artist can choose any effect giving the ability to save it right away.
Please check the documentation link to refer the render examples [ https://docs.otoy.com/BlenderH/BlenderP ... Imager.htm ]
Kind Regards
bk3d
J.C
Hi JC,
cheers
So what it is for?
What happens when I increase this to 100 sec or decrease 1sec?
System – Windows 11
milanm
It was introduced in the early v3 versions as a means of troubleshooting problems that users with slow PCI-X speeds were having. In V3 the framebuffer was moved to RAM so the frequent transfers of data to and from GPU were causing problems, even more with baking camera and high resolutions. At least that's my understanding of it. Later they also added options to disable tonemapping for specific GPUs for the same reason.
viewtopic.php?p=259447#p259447
viewtopic.php?p=277819#p277819
Cheers
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
J.C
@milanm, thanks for information!
System – Windows 11
Return to “Blender”
