Hi.
I am trying to blend between 2 materials. And mix materials sound like the logical and only option to do that.
Sadly i ain't getting the result i am looking for.
As you can see from the gif i have attached, i want to blend from a RAW state to a Grilled state.
Having made a RAW material and a Grilled material i now try to blend between them using the mix node.
The problem is that it gets brighter before it gets darker again.
I belive this has something to do with both materials beeing 50% each in the middle of the transition.
Does it exist another way to blend them? like have the other material ONTOP of the other?
Like:
Base material 100%
layer1 - animating from 0-100%
Instead of how mix material work right now
Material1 100 to 0%
Material2 0 to 100% (atleast that how i think it works, i am just guessing)
I hope my explanation is not to confusing.
Thank you
-Mats
Mix material - other options?
- paride4331
Hi stir,
you could animate the materials but the textures also and at the same time. you could use a texture in amount like alpha.
Or use the compare texture node.
viewtopic.php?f=27&t=61208&p=313128&hil ... on#p313128
- rik.mp4
- (6.64 MiB) Downloaded 1472 times
thanks for the reply paride.
i'm not sure i understand what you are saying.
Putting a texture inn the amount slot instead of animating it from 0-1 shouldn't make a difference when it comes to the "brightness" issue.
I will add a map in the amount later on as this will give a more organic and interesting breakup in the transition.
But right now i need to stop it from brightening up.
After digging a bit more it seems to be somewhat connected to the SSS (specular) material.
As you can see on the picture i added.
I have a "raw" material and a "grilled" material. each of these compose of a glossy and a specular material that is mixed with 0.4 value.
If i turn these mixes to 1 so only the glossy materials is in effect and animate the "morph" mix node from 0 to 1 the colors/brightness animate as expected.
If i keep them at 0.4 and animate the morph node it gets that increased brightness before it goes dark again.
a solution might be, instead of having 2 separat materials like now that i try to mix between, i just have 1. and animate all the different values and blend all the different maps innside that one shader.........but that sound like a painful job.....
Best regards
-Mats
Best regards
-Mats
- paride4331
Hi Stir,
this is using only mix material, changing specular in 2 steps.
- 01.zip
- (3.71 MiB) Downloaded 199 times
