Camera Projection problem
Sub forum for help and tutorials.
seb6996
I would like to project an image (text) on a cube and the behind wall, but don't want the part of the image which is on the front cube also on the wall.
I try the baking camera with no result.. Please help !
See attached C4D file
Many thanks
Projection.zip
(238.52 KiB) Downloaded 282 times
what about changing the object color to white, of the general cube, in order to obtain the desired mask with an object layer color pass? But it’s not completely clear to me what do you want to obtain, sorry :roll:
ciao beppe
seb6996
Thanks for your reply,
I want something like that, the sentence is correct only at the end of the camera movement.
= A projection that stop with the objet in front (the cube)
Is is more clear ? An idea
Thanks !
Don't try to do it with octane projections. Just make a proper setup with C4D camera+camera_projection from texture tag. Then Octane plugin will generate proper results.
seb6996
Thanks, i will try this way
Return to “Help / Tutorials”
