instances + UVWmap render speed problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ramone163
3ds max 2017 - v3.07 - 4.44
Objects: balls, instances, movable proxy.
Everything rendering fine. But when I add UVWMap to all objects, evaluation and render time is x20 time slower. But GPU mem used is same: 0,5 Gb.
Can you please fix this.
Check my images:
Objects: balls, instances, movable proxy + UVWmap
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
paride4331
Hi ramone163,
4.44 seems to work correctly.
Would you like to share your scene I could take a look at it.
ramone163
Hi paride4331.
I think you just selected one ball and added UVWmap? Try to select all balls and add one UVWmap.
Please check my scene:
Try to render for example frame 50. Then select all balls and delete UVWmap and render again. You will see the difference.
Best,
ramone
Balls_Baked_01_test.zip
(2.25 MiB) Downloaded 198 times
ramone163
One more thing in my scene:
1) objects are instances with MovableProxy - render time 1 sec
2) objects are unique with MovableProxy - render time 10 sec
3) objects are unique without MovableProxy - render time 4 sec
paride4331
Hi Ramone163,
thanks, I will report this issue to developer to better understand.
Return to “Bug Reports”
