Dissolve distance to object
ruuterdetuuter
Do any of you know how to dissolve an surface by its distance to an object?
Thanks in advance.
Ruud
paride4331
Hi ruuterdetuuter,
a simply trick could be to use dirt map node in opacity slot.
ruuterdetuuter
Thanks for the suggestion, I was hoping to control it by a NULL objects, this so I can erase objects and appear new ones.
juanjgon
The plugin supports the object properties "Object Dissolve" feature. Perhaps you could build an expression in the "E" envelope tool to control this value and reference it to a distance to a null object.
Return to “Lightwave 3D”
