Question about gradient
RzK
Hi everyone!
I have a high poly mesh without UV's and I want to darken the botton of a mesh to use it as additional multiply for a diffuse.
Is it possible to do with a gradient map or any other way?
It seems that gradient itself works as a controller and I can't find a way to wire a UV mapping node to it. Or maybe there is other way to make this gradient effect happen?
Appreciate any help!
paride4331
Hi RzK,
something like this?
sample.zip
(18.33 MiB) Downloaded 161 times
RzK
Hey, paride4331! Exactly what I needed. You used sine wave as a dud for uv projection and transformation. Elegant solution :)
Return to “Autodesk 3Ds Max”
