Hi Guys,
I will ask about wetmap news, I'll keep you posted.
OctaneRender® for 3ds max® v3.07 - 4.44 [OBSOLETE]
- paride4331
Hello!
Thinking of the 3.08 release for 3DS Max, as I have been using the most recent development build SA.
Is the plan for the plugin to also have the ability to use .cube/LUT files, like the standalone will?
Regards & THX!
Regards & THX!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Plugs: Enterprise
- richardyarlett
Guys, I have to tell you that this entire build, since 3.06 is just so buggy. I have tried three times to leave 3.06 and go to any of the 3.07 systems, and non of them work with MOVABLE PROXYs. They do not act correctly. They do not move, or load in and out of memory properly. I get frozen geometry and corrupt geometry. Its a REALLY BASIC problem guys. How has then not been address in all of these versions of 3.07. FIX IT PLEASE. MOVEABLE PROXYs are REQUIRED.
Hi Paride,
it seems that octane particles do not work with phoenix. I attached the scene if you simulate 50 frames or so and then render you will see no foam is rendered. Thank you
and we are using the latest phoenix 3.0502 it seems 3.04 worked fine and we are also using 2018 update 4 3ds max
update switching to 3.04 did nothing it is either octane or new max update?
- boat.zip
- (126.63 KiB) Downloaded 218 times
- paride4331
Hopefully they can fix it soon
I have a question about system units setup. Yesterday i browsed another thread where a "1 Unit = 1 Meter" was suggested to have Octane work right. For years I work with "1 unit = 1 centimeter". PLus I checked the bix "respect system units in files".
Whats the difference? Is there an optical difference? Rendertimes? I set it to meters in one scene but my building was not 5m height but 500meters then.
Would be nice to get some explanaitions.
PURE3D Visualisierungen
- Elvissuperstar007
- Contact:
displacement octane projection does not work
