OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Daniel_Ward
Hi Paul,
displacement mapping certainly is much improved in 3.08. Could you do an ArchiCAD plugin update based on the version 6 build, just keen to see if it can resolve the displacement at corners a bit better than the v5 build?
Have a great Christmas and New Years break.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Sorry Dan - there are issues with TEST 6 which make it impossible to deliver a test build for you. So unfortunately if will need to wait for TEST 7.
Daniel_Ward
Hi Paul,
how's 3.08RC1 looking?
Cheers, Dan.
I am scheduled to have the ArchiCAD plugin done next Tues.
I have updated the TEST release builds at the top of this thread with:
3.8.0.80
- Compiled with Octane 3.08 RC1 (see viewtopic.php?f=33&t=63219 for details)
- Toon shading only works in Camera Light toon lighting mode.
- All Image, Alpha Image and Float Image files are now loaded with HDR Texture Bit Depth set to Automatic
* Material picking from a scaled Viewport issue has not yet been fixed
* "Import from LiveDb/LocalDB - EXPERIMENTAL" is still disabled
Daniel_Ward
Hi Paul,
I'm finding that if I'm using displacement, in the "Displacement Direction", I can't get the AC plugin to use the "BRDF : Follow Smoothed Normal"
If I export the project as an OCS it works fine in Standalone.
The issue is that when you select "Follow Smoothed Normal" in standalone is does a pretty good job of stitching up the seams on corners where displacement is occurring, with out it, the corners get left open.
I could just be doing something completely wrong though! :D
Cheers, Dan.
I have updated the 3.08.0.08 release installers at the top of this thread to correct this issue.
Daniel_Ward
Hi Paul,
I'm still not having much luck with this sorry.
I am observing the following;
Selecting Follow Vertex Normal, or Follow Geometric Normal, both end up with the Follow Vertex Normal settings.
Selecting Follow Smoothed Normal ends up with the Follow Geometric Normal settings.
I'm getting the same behaviour with both the AC20 and AC21 plugin.
Cheers, Dan.
Jasonr
Haven't tested it yet because of other work but just to know is this happening only with the plug in??
If you export to to standalone is it wokring properly?
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Thanks - I have located the problem, and it will be fixed in the next release.
Return to “Graphisoft ArchiCAD”
