Hey there,
i want to render some volumetric lights. Octanes Problem in this field is that it produces a lot of noise near the light source. Adaptive sampling would be ideal to get rid of this noise, but even at 1020 Samples (which is the maximum) the noise is so bad that the algorithm fails and keeps black spots because it considers them as noisefree. Is 1020 a random number and could this be increased?
Adaptive Samples Minimum Samples too low
- Hesekiel2517
Thank you very much for the quick response! That helps me a lot!
But this value is stucked at 1020 in the MAx plugin...did I read it wrong? or is there a way to increase it too?vijay_thirukonda wrote:Yes, the min samples can be increased. Select it and just type in a value without using the slider.
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Sorry,justix wrote:But this value is stucked at 1020 in the MAx plugin...did I read it wrong? or is there a way to increase it too?vijay_thirukonda wrote:Yes, the min samples can be increased. Select it and just type in a value without using the slider.
Christophe will fix this in a future Max plugin release.
In Standalone, The minimum adaptive sample can be set up to 1 million. But I restricted the maximum slider value to 1024 because I thought 1024 is good enough and I'm wrong. To make things clear, I will remove the slider restriction in next release.
VJ
cinema 4d too !justix wrote:But this value is stucked at 1020 in the MAx plugin...did I read it wrong? or is there a way to increase it too?
pxlntwrk.net
pxlntwrk.net
In the Blender plugin the slider stops at 1024, but you can click on the slider and set it to what you need.
Jason
Jason
Thanks for thatvijay_thirukonda wrote:Informed Ahmed as well, He will increase it in a future release.pxlntwrk wrote:cinema 4d too !justix wrote:But this value is stucked at 1020 in the MAx plugin...did I read it wrong? or is there a way to increase it too?
VJ
pxlntwrk.net
pxlntwrk.net
