TUTORIAL: How to use RenderTargets for powerful scene setups
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
archigrafix
abstrax wrote:
Jaberwocky wrote:Thanks marcus
So to clarify.
I could for example create 24 camera positions across say 10 obj files , sharing tonemapping/lighting etc all loaded in 1 ocs file.That file would load into the Host CPU memory where it will be voxalised and held ready for when i click on a camera node.After the camera node is clicked only that portion required is sent to the GPU memory to be rendered.
So if i have a huge scene i could split the obj files and as long as i have say 16-32Gb of memory (which of course is very cheap nowdays) i need only have a 1-2 gb Video card.
That may also answer the 64 node limit problem on textures. :o
Yes you could do that. Obviously the whole node graph may get a bit "messy" but I don't see a reason why it should not work.
Cheers,
Marcus
Do you mean we can combine a scene with multiple obj meshes?????
I thought it wasnt possible: I tested myself and I dont find a way to attach for example 2 different meshes on one render target
t_3
archigrafix wrote:Do you mean we can combine a scene with multiple obj meshes?????
imo what they are discussing is, to split a big scene into smaller parts and render them one after the other within one scene. would need post compositing anyways (and doesn't sound really practicable to me).
currently you can't render different mesh node at once - but afaik the upcoming instancing update will allow exactly that...
„The obvious is that which is never seen until someone expresses it simply ‟
archigrafix
thanx T3. Of course it is a workaround and better than nothing but then object wont interact between them (shadows reflections etc...)
Any idea of timing for instances... I know you get used (bored?) about that sort of question but it is a so long time request
t_3
archigrafix wrote:thanx T3. Of course it is a workaround and better than nothing but then object wont interact between them (shadows reflections etc...)
never mind - i'm only forum mod and have no insight in refractive's secret schedules (nor their not so secret) ;)
imo what should describe it best: "when it's done" :)
jalley
Hi there,
I came back to this post after - actually - afew years ;-). Sounds like I am "Back to the Future" (last post was 5 years ago). Anyway, the thing is I am using Octane with Unity, and I am wondering if it would be possible to use an Octane setup where I render multiple cameras within a single frame. Is there a way to do that by using different PBR Render Targets? The problem of Octane in Unity now, is that you can not script the camera linked to the PBR Render Target, so I had to replicate PBR Render Targets having one for each camera. However to change cmaera I need to click 'Render' on each separate Render Target.
So, I am wondering if there is a way to automatize this procedure, having in mind, current limitation of Unity+Octane in terms of scripting. Can this be replace with some smart Octane Node construction?
Thank you so much,
jalley
BTW, I am in 2017 now ;-)
Goldorak
jalley wrote:Hi there,
Thank you so much,
jalley
When we drop 3.08 into Unity, OSL camera node, all sorts of crazy programmable ray traced camera options open up from a single node.
Hi jalley,
you have reopened a very old discussion.
Please, refer to this forum section for Unity support and questions:
viewforum.php?f=129
All the discussions are from 2017 ;)
ciao beppe
Locked
Return to “Resources and Sharing”
