https://unity3d.com/get-unity/download/archive and then select the Unity 2017.1.0 version.Dmonty wrote:I'm using Unity Unity 2017.1.1f1 but I cannot install. it keeps saying "No compatible unity version is installed." I cannot find f3 or f3. can someone direct me to it? Thank you.
Octane for Unity - Installation Guide (rev. July 31st, 2017)
Moderator: ChrisHekman
- ChrisHekman
- amathews9518
I get this error when starting Unity.
Any advise?
Any advise?
W764 2xE5 2650 3-780(3GB) + 780TI(3GB) Asrack EP2C602 40gb Lightwave & Chief Architect
- ChrisHekman
That should not interfere with the working of Octane for Unity.amathews9518 wrote: I get this error when starting Unity.
Any advise?
I am going to take a look at it though. Thank you for the report.
- ChrisHekman
Having a slow internet/low bandwidth is not necessarily the cause of the timeout. Connection loss is more likely. Using a vpn might also cause the issue.xCyborg wrote:I can't download Octane ver 1.1 (Download timeout. No data received for the past 20 seconds). I have connection but kinda slow, please fix or provide full installer installation-wide, thanks.
Ill check if we can add a re-connect when the timeout happens.
I just downgraded the freshly installed Unity 2017.3 to 2017.2.1 to try this after some dll-errors, but now I get the above error stating that I have no valid license. Should that still happen? It was advertised that I am able to use and test for free.limeforce wrote:Hi guys, so an OctaneVR subscription is required to test the alpha? No dice with a purchased standalone license?
Edit: I have read the docs on unity.octane.com but no real help there. If I try to login with the Octane account the above happens. If I try to login with my Unity account nothing happens and I get the following error message in the console:
Failed: System.InvalidOperationException: Unexpected response from server.
UnityEngine.Debug:LogError(Object)Edit: You have to do a lot better to expect me to pay money for this ...
Regards,
Xanathon
