OctaneRender® for 3ds max® v3.07 - 4.42 [OBSOLETE]
coilbook
Hi was this diffuse transparency bug fixed? viewtopic.php?f=81&t=61299
paride4331
Hi coilbook,
yes it is.
ryan34side
Hello
there is a problem with the rendering when we launch a small rendering everything is fine I leave the rendering I change something and I redo the rendering and the window is black. there is no error in the log but I have to restart the scene.
try with just 1 light. because I think the problem comes from the lights
nicolas
paride4331
Hi ryan34side,
could you give me more info, your issue workflow or screenshots?
ryan34side
paride4331 wrote:Hi ryan34side,
in fact I found the problem but I have not resolved I saw nothing in my scene because when I check movable proxy the object disappears when rendering? is a bug? look at the scene
simple scene.rar
(44.46 KiB) Downloaded 304 times
paride4331
Hi ryan34side,
Yes it is an issue around movable proxy:
viewtopic.php?f=80&t=63857#p325466
4.42 is a test version, I think it will be fixe asap.
ryan34side
yes ok sorry ! :D
thanks you very much !!
coilbook
Hi Paride
I cannot tell the difference between AO texture and AO distance. Should we keep AO texture at 1? It seems that lowering AO texture or increasing AO distance makes similar images Thanks
paride4331
Hi coilbook,
AO also depends on the size of the scene, so small objects may not see much difference.
coilbook
paride4331 wrote:Hi coilbook,
Thank you
By the way is there anyway to have light emitting mesh (plane emitting caustic map on a ground) but have plane invisible? Thank you
Return to “Releases”
