Hi was this diffuse transparency bug fixed? viewtopic.php?f=81&t=61299
OctaneRender® for 3ds max® v3.07 - 4.42 [OBSOLETE]
- paride4331
- ryan34side
Hello
there is a problem with the rendering when we launch a small rendering everything is fine I leave the rendering I change something and I redo the rendering and the window is black. there is no error in the log but I have to restart the scene.
try with just 1 light. because I think the problem comes from the lights
nicolas
nicolas
- paride4331
Hi ryan34side,
could you give me more info, your issue workflow or screenshots?
- ryan34side
paride4331 wrote:Hi ryan34side,
in fact I found the problem but I have not resolved I saw nothing in my scene because when I check movable proxy the object disappears when rendering? is a bug? look at the scene
- simple scene.rar
- (44.46 KiB) Downloaded 312 times
- paride4331
Hi ryan34side,
Yes it is an issue around movable proxy:
viewtopic.php?f=80&t=63857#p325466
4.42 is a test version, I think it will be fixe asap.
- ryan34side
yes ok sorry !
thanks you very much !!
- paride4331
Thank youparide4331 wrote:Hi coilbook,
AO also depends on the size of the scene, so small objects may not see much difference.
By the way is there anyway to have light emitting mesh (plane emitting caustic map on a ground) but have plane invisible? Thank you
