Overview of OSL Shaders in Octane
calus
J.C wrote:Thanks calus. This compiles now but it does not work as advertised by Chaos group. The flakes does not scale. I just can see some two big triangles.
hum, it works as expected for me, but take care as there is no input for projection , Octane use UVprojection by default so your geometry need some UV, or if you want to work without UV triplanar proj should work.
Pascal ANDRE
You should slightly modify parameters and code. See image.
J.C
Thanks guys for the tip, it works! :)
System – Windows 11
Doing some tests with codes from internet while improving the stuff.
simple deformation with osl_projection.
shader OslProjection
     color dist=0,
    output point uvw = 0
    uvw = 2*point(u, v, 0)+dist;
Brick
shader brick(
        float thick=0.02,
        float rat=5.6,
        float  rep=6,
        color MainColor = color(1.0,0.0,0.6),
        color EdgeColor = color(1.0,0.0,0.0),
        output color c = 0 )
    color col=color(1,0.23,0.13);
    float x=rep*u;
    float y=rat*rep*v;
    if(mod(y, 2.0) < 1.0) x=x+0.5;
    x *= (1+0.7*noise("cell", y));
    float nx=x-floor(x);
    float ny=y-floor(y);
    if(nx>1-thick || ny<rat*thick) {
        col=color(0.9);
    else {
        float brg = 0.5*noise("cell", point(floor(x),floor(y),0))+0.3;
        col = brg*col;
    c = col;
Crazy parquet script
shader DWParquetTile (
        float DiffuseAmt = 0.75 ,
        float SpecularAmt = 0.15,
        float Roughness = 0.025,
        color SpecularColor = color(1.0),
        float RingScale = 25.0,
        float GrainScale = 55.0,
        float Grainy = 1.0,
        float Wavy = 0.08,
        float TextureScale = 5.0,
        color LightWood = color (0.57, 0.292, 0.125),
        color DarkWood  = color (0.275, 0.15, 0.06),
        color GrooveColor  = color (0.05, 0.04, 0.015),
        int PlanksPerTile = 1,
        float PlankWidth = 0.2,
        float PlankVary = 0.6,
        float GrooveWidth = 0.1,
        output color BSDF = .5 )
#define snoise(x) (2 * noise((x)) - 1)
#define boxstep(a,b,x) (clamp(((x)-(a))/((b)-(a)),0,1))
#define MINFILTERWIDTH 1.0e-7
        vector Vector = P;
    float su = Vector[0];
    float tv = Vector[1];
    float r, r2;
    point Nf;
    float whichrow, whichplank;
    float swidth, twidth, fwidth, ss, tt, w, h, fade, ttt;
    color Ct, woodcolor;
    float groovy;
    float PGWIDTH, PGHEIGHT, GWF, GHF;
    float tilewidth, whichtile, tmp, planklength;
    PGWIDTH = PlankWidth+GrooveWidth;
    planklength = PGWIDTH * PlanksPerTile - GrooveWidth;
    PGHEIGHT = planklength+GrooveWidth;
    GWF = GrooveWidth*0.05/PGWIDTH;
    GHF = GrooveWidth*0.05/PGHEIGHT;
    /* Determine how wide in s-t space one pixel projects to */
    swidth = (max (abs(Dx(su)*su) + abs(Dy(su)*tv), MINFILTERWIDTH) / PGWIDTH) * TextureScale;
    twidth = (max (abs(Dx(tv)*su) + abs(Dy(tv)*tv), MINFILTERWIDTH) / PGHEIGHT) * TextureScale;
    fwidth = max(swidth,twidth);
    ss = (TextureScale * su) / PGWIDTH;
    whichrow = floor (ss);
    tt = (TextureScale * tv) / PGHEIGHT;
    whichplank = floor(tt);
    if (mod (whichrow/PlanksPerTile + whichplank, 2) >= 1) {
        ss = TextureScale * tv / PGWIDTH;
        tt = TextureScale * su / PGHEIGHT;
        tmp = swidth;  swidth = twidth;  twidth = tmp;
    ss -= whichrow;
    tt -= whichplank;
    whichplank += 20*(whichrow+10);
     * Figure out where the grooves are.  The value groovy is 0 where there
     * are grooves, 1 where the wood grain is visible.  Do some simple
     * antialiasing.
    if (swidth >= 1)
        w = 1 - 2*GWF;
    else {
        w = clamp (boxstep(GWF-swidth,GWF,ss), max(1-GWF/swidth,0), 1)
        - clamp (boxstep(1-GWF-swidth,1-GWF,ss), 0, 2*GWF/swidth);
    if (twidth >= 1)
        h = 1 - 2*GHF;
    else {
        h = clamp (boxstep(GHF-twidth,GHF,tt), max(1-GHF/twidth,0),1)
        - clamp (boxstep(1-GHF-twidth,1-GHF,tt), 0, 2*GHF/twidth);
    /* This would be the non-antialiased version:
     * w = step (GWF,ss) - step(1-GWF,ss);
     * h = step (GHF,tt) - step(1-GHF,tt);
    groovy = w*h;
     * Add the ring patterns
    fade = smoothstep (1/RingScale, 8/RingScale, fwidth);
    if (fade < 0.999) {
        ttt = tt/4+whichplank/28.38 + Wavy * noise (8*ss, tt/4);
        r = RingScale * noise (ss-whichplank, ttt);
        r -= floor (r);
        r = 0.3 + 0.7 * smoothstep(0.2, 0.55, r) * (1 - smoothstep(0.75, 0.8, r));
        r = (1-fade)*r + 0.65*fade;
         * Multiply the ring pattern by the fine grain
        fade = smoothstep (2/GrainScale, 8/GrainScale, fwidth);
        if (fade < 0.999) {
            r2 = 1.3 - noise (ss*GrainScale, (tt*GrainScale/4));
            r2 = Grainy * r2*r2 + (1-Grainy);
            r *= (1-fade)*r2 + (0.75*fade);
        else
            r *= 0.75;
    else
        r = 0.4875;
    /* Mix the light and dark wood according to the grain pattern */
    woodcolor = mix (LightWood, DarkWood, r);
    /* Add plank-to-plank variation in overall color */
    woodcolor *= (1-PlankVary/2 + PlankVary * noise (whichplank+0.5));
    Ct = mix (GrooveColor, woodcolor, groovy);
    Nf = normalize(N);
BSDF =  Ct * DiffuseAmt;
   // BSDF = Ct * DiffuseAmt * diffuse(Nf);
  //  BSDF += SpecularColor * SpecularAmt;
sbstnc
This is amazing, any plans to add an OSL section the Live Database? Would be a handy way to collect and submit these types of materials.
camera shader test
#include <octane-oslintrin.h>
shader OslCamera(
    color dist=0,
    output point  pos  = P,
    output vector dir  = 0,
    output float  tMax = 1.0/0.0)
    float pa;
    int res[2];
    getattribute("camera:pixelaspect", pa);
    getattribute("camera:resolution", res);
    //point n = noise("noise", 4*point(u,v,0));
    color  n = _evaluateDelayed(dist, u, v);
    float aspect = pa * res[1] / res[0];
    vector right = cross(I, N);
    dir = I + right * (u - .5) + N * (v - .5) * aspect + 0.1*(n);
Jolbertoquini
Hi Guys,
Quick question? I was looking at the flakes how to use with triplanar projection ? on stadalone? Just a curiosity.
Cheers,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
funk
Jolbertoquini wrote:Quick question? I was looking at the flakes how to use with triplanar projection ? on stadalone? Just a curiosity.
I added a projection pin then used it in the position calculation like this:
shader
flakes
    float flake_scale = 10.0 [[ string description = "Smaller values zoom into the flake map, larger values zoom out" ]],
    float flake_size = 0.5 [[ string description = "Relative size of the flakes" ]],
    float flake_size_variance = 0.0 [[ string description = "0.0 makes all flakes the same size, 1.0 assigns random size between 0 and the given flake size" ]],
    float flake_normal_orientation = 0.0 [[ string description = "Blend between the flake normals (0.0) and the surface normal (1.0)" ]],
    point proj = point(u, v, 0) [[string label = "Projection"]],
    output color result = 1.0
    float safe_flake_size_variance = clamp(flake_size_variance, 0.1, 1.0);
    vector cellCenters[9] = {
        vector( 0.5,  0.5,  0.0),
        vector( 1.5,  0.5,  0.0),
        vector( 1.5,  1.5,  0.0),
        vector( 0.5,  1.5,  0.0),
        vector(-0.5,  1.5,  0.0),
        vector(-0.5,  0.5,  0.0),
        vector(-0.5, -0.5,  0.0),
        vector( 0.5, -0.5,  0.0),
        vector( 1.5, -0.5,  0.0)
    //point position = vector(u, v, 0.0);
    point position = flake_scale * proj;
    point base = floor(position);
    point nearestCell = point(0.0, 0.0, 1.0);
    int nearestCellIndex = -1;
    for(int cellIndex = 0; cellIndex < 9; ++cellIndex)   {
        point cellCenter = base + cellCenters[cellIndex];
        vector centerOffset = cellnoise(cellCenter) * 2.0 - 1.0;
        centerOffset[2] *= safe_flake_size_variance;
        centerOffset = normalize(centerOffset);
        cellCenter += 0.5 * centerOffset;
        float cellDistance = distance(position, cellCenter);
        if(cellDistance < flake_size && cellCenter[2] < nearestCell[2]) {
            nearestCell = cellCenter;
            nearestCellIndex = cellIndex;
    result = color(0.5, 0.5, 1.0);
    if (nearestCellIndex != -1) {
        vector randomNormal = cellnoise(base + cellCenters[nearestCellIndex] + vector(0.0, 0.0, 1.5));
        randomNormal = 2.0 * randomNormal - 1.0;
        randomNormal = faceforward(randomNormal, I, randomNormal);
        randomNormal = normalize(mix(randomNormal, vector(0.0, 0.0, 1.0), flake_normal_orientation));
        result = color(0.5*randomNormal[0]+0.5, 0.5*randomNormal[1]+0.5, randomNormal[2]);
calus
Well done Funk :)
Pascal ANDRE
Jolbertoquini
funk wrote: I added a projection pin then used it in the position calculation like this:
Hi Funk,
Thanks nice move :) yeah!
