material error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
raoulbattilani
added the material but I do not see any change to my sphere and this is a error message .
houdini version 16.0.633
octane version 3.07.0.1
any solution?
juanjgon
Are you using the 16.0.633 Octane plugin build with your Houdini version? It is a weird issue, I had not see these errors before, and here the materials system seem to work fine.
Can you please attach one scene with this problem to test it here?
raoulbattilani
yes i'm a using Octane_3.07.0.1_Houdini_16.0.633_Win64 plugin folder
Raoul
materialerror.zip
file scene
(40.38 KiB) Downloaded 242 times
screenshot error
screenshot error
juanjgon
These materials come from LiveDB, right? I think that the main problem is they have space characters in their names, something not supported by Houdini. You need to rename the material node, removing the space characters. Also be aware that the "Cracked_Paint" material is not valid, it is only a texture node, without a material node to apply it.
Hope this helps,
Return to “Bug Reports”
