OctaneRender® for 3ds max® v3.06.4 - 4.41 [OBSELETE]
coilbook
Hi Paridie
Any news from otoy to make wetmaps for Phoenix as procedural mask texture and not as a 3d particles? Thanks
paride4331
Hi coilbook,
I will recap about the required PhoenixFD features.
Elvissuperstar007
corona 1,7 this is a normal library!
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
coilbook
paride4331 wrote:Hi coilbook,
Thank you!
Goldisart
https://www.youtube.com/watch?time_cont ... Bz_fnycYD4
I'm going to torment you but you have to make friends with the octane with the standard procedural maps 3d max :D :D :D :D :D :D
note the standard falloff is not working most of the features of camera X, Y, etc.
or you will suffer the same fate as the corona render :) you buy chaos grupp :mrgreen:
I understand that there are octane noise .... but when I'm working on a big project I get scenes from studios who work with Vray and use the standard methods use the standard noise 3Dmax
although I can repeat ... but I can't sync it with a standard noise ----- great app
acc24ex
The "Use production resolution" is still not fixed - it's never working when I need it..
Come on octane guys - complain to your bossed to hire another programmer - as they have enough money to hire lawyers against fstorm, you know they earn 10x your pay
- can't fix simple stuff 10 versions later is very annoying
paride4331
Hi acc24ex,
waiting to fix this minor issue, you simply have to double click on image aspect Lock in common parameters tab.
darkline
Hi Paride
Any comments on the issues I posted? Can you recreate any of these problems or does it all work fine for you?
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
coilbook
HI Paride
any news on using phoenix RGB to create different color smokes, liquids in one sim. Like this video https://youtu.be/6k9YL98TT7U or this one https://youtu.be/0AySkEXqESk
Thank you
DartFrog
It looks like 4.41 doesn't respect Mesh UV projection. I have a material with 3 UVW maps on it using channels 1-3 and the material has different maps set for different channels, all set for 1-3. Any help is appreciated.
Return to “Releases”
