Script for viewport button
fabrizio_s
I'd like to create a button that creates a new viewport with the same size of Film Settings Resolution. Now I write the film size manually in the script of the button.
Do you know how to copy the values of the octane film setting and put automatically in the script?
thanx
I'm not sure you can change the resolution settings via a Rhino command. I will need to check early next week, and add that functionality if it is not already there.
fabrizio_s
Thank you very much, Paul!
franchais
yes it would be great to be able to save your own viewport resolutions
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
fabrizio_s
here is a button that creates a viewport with the dimension (or percentage) of the Octane rendering viewport. The script isn't mine because I'm not a coder. I asked in the Rhino forum how to write this script and two coders helped me to build it.
For now, the resolution of this window doesn't come automatically from the octane film setting. You have to change it manually (shift+right click) inside the code of the button.
Hope you like it
http://www.filedropper.com/octaneviewport
fabrizio_s
Hi Paul,
did you try to look at this functionality?
bye
Hi, I am trying to get all the 3.07 final releases done, and will then take a look. Sorry for the delay.
fabrizio_s
ok thanx
Return to “Rhinoceros 3D”
