Fur Cd workflow
Houdini Integrated Plugin
ptunstall
Hey so I followed the guide used for particles you have in the documentation to get fur to pickup the Cd color but doesn't seem to work right and I don't know what I'm doing wrong. I created a shader assigned the PPM texture to the diffuse. Then on the octane parameters I ticked on Cd colors.
juanjgon
It should work, but the hair curves need the Cd attribute at the primitive level. Attached you have a sample scene, you only need to set the texture from your folder in the hair material.
002_h16HairWithCdAttribute.rar
(51.54 KiB) Downloaded 375 times
ptunstall
Ohhhhh primitives Cd ok cool! Yay thank you!
ptunstall
ok so is there a way to get variation in color along a single strand via Cd? I'm trying to match something like this. I know this is probably more of a houdini question than octane.
http://data.whicdn.com/images/90557668/original.jpg
juanjgon
Sorry, not directly from a Cd attribute at point level. You have the Tool W Coordinate node that can be used for example with the gradient node to shade the fur along the strand.
Return to “Houdini”
