Octane for Softimage 3.00 RC3 Demo/Full [Current]
face
The focus of this update is a better ICE integration.
Happy testing,
face
FIXED:
  • The gradient node wasn´t deleted if a material was deleted.
  • PointCloud kinematics node wasn´t deleted if a regular Pointcloud contains no data.
ADDED:
  • Added support for particle motionblur, deformed motion blur from the mesh property must be set to true.
  • Added support for strand motionblur, deformed motion blur from the mesh property must be set to true.
  • Pointcloud possibility to mix internal shapes with external instance shapes.
  • Pointcloud internal shapes can have an object layer, instance shapes will use the instance object layer.
  • Pointclouds can be used as instance shapes.
  • Pointclouds with animated kinematics can be rendered with motion blur.
  • Parts of the strand generation will be generated in multithreaded if the count of strands is greater than 10000.
CHANGED:
  • Redesigned PointCloud class.
DOWNLOADS INSTALLATION INSTRUCTIONS
  • This plugin can be installed with the usual way. Unzip the downloaded OctaneV3.zip, drag and drop the xsiaddon in the Softimage window.
    You can also use the File -> Addon -> Install menu.
KNOWN ISSUES
  • None.
http://vimeo.com/user2509578
wireframex
Thanks Face
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
rray
The post still has the RC2 links (and description I believe)
Core i7 980 x GTX 980
face
Had wrought the RC2 thread as RC3 ;)
rray
Nice list :) Looking forward to be playing with this soon!
abeoctane
Hi face, I downloaded the demo but It seems the hair does not work, does the hair render with this version of octane for softimage?
face
Strands will work, hair aren´t included.
But i can take a look how tricky it is to include.
face
face
First hair test...
abeoctane
Hi face, the test looks very cool, hope to be able to test the hair it soon, when you release the next demo. :D
rray
Nice!! A mini feature wish, just for tidyness: Other renderes have a submenu in get->material, it would be nice if Octane had it too (even though it deserves the extra space :D )
Return to “Autodesk Softimage XSI”
