Here is new topic for version 3.07 Test6a which is based on a SDK(3.07 Test6).[/b].
You can find a detailed description of the new 3.07 features of Standalone in this thread: viewtopic.php?f=33&t=62395
Changes of 3.07
- New InstanceColorID support for objects/particles.
- New textures: InstanceColor, InstanceRange, Baking texture, UvwTransform texture.
- Volume object update detection
- Node editor: Undo/redo update issue on embedded editor with node parameters
- Fix: Crashes with Meshno>3 on Object tag
- Scatter object: Animated/deformed objects support on distribution slot. Fix wrong weights on effectors. Fix unnecessary calculation on camera navigation. Instance color support. Shader effector UV support.
- Initial colorID support for particles/scatter object.
- Fix: Broken "-exportORBX" commandline parameter.
- Better Camera MotionBlur processing for fixing some issue of CamMoblur detection.
- Fix: Triplanar bug on handling of initial channel.
- Triplanar node, single texture improvement.
- Change: Internal diffuse color changed from gray to black for internal material of Light Tags. It may cause a small amount difference on results of illumination effect.
- Floor object support added. Tiling from texture tags will not work. So use transform nodes in textures for scaling.
- Node Editor: Solo mode for textures
- Fix scatter: Wrong uv sampling on distribution of scatter with tiled mode
- min. requirement changed for R18. It's now 18.057
- Fix: Crash on R19 with deleting nodes in node editor
- Several small fixes
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... 6a-win.zip
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OctaneRender™ Standalone 3.07 test6
viewtopic.php?f=33&t=62998
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.024). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(at least 37x.x(Cuda 8.0) - rollback to versions if you have much trouble with latest drivers
MANUALS:
Offline HTML: https://render.otoy.com/plugindownloads ... ual-V3.zip (extract to c4doctane directory)
Online manual: https://docs.otoy.com/#cinema-4d-v3-int ... -4d-plugin
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Test Version 3.07-Test6a
- instance-ids.rar
- (477.98 KiB) Downloaded 611 times
- xp-instance-colors.rar
- (177.61 KiB) Downloaded 517 times
YES! I have been waiting for better XP integration desperately!
Thanks Ahmet!
Thanks Ahmet!
Windows 8.1/Cinema4D R16/1x GTX 980Ti + external GPU expander with 2x GTX 980Ti's and 2x GTX 970's
- jeffbriant
- Contact:
YES! AOKTAR IS A BEAST!
2x1080's network rendering to 4x980Ti's
- Steeviekay
Awesome Aoktar!!! Installing it now. Thanks!
Thanks a lot Aoktar !!
The delete works fine now in Node editor with R19.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Awesome thank u! If we could access the bar by pressing TAB and enter for the node like nuke would be perfectStudio21 wrote:ohhhh....just found there is a new search bar in the node editortyvm Ahmet!!!
Maybe later.thanulee wrote:Awesome thank u! If we could access the bar by pressing TAB and enter for the node like nuke would be perfectStudio21 wrote:ohhhh....just found there is a new search bar in the node editortyvm Ahmet!!!
Oh shit, so this is possible ? haha, would love a commander like function in the node editoraoktar wrote:Maybe later.thanulee wrote:Awesome thank u! If we could access the bar by pressing TAB and enter for the node like nuke would be perfectStudio21 wrote:ohhhh....just found there is a new search bar in the node editortyvm Ahmet!!!
