Day Light Render
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
JNDesign
Hi All
I am using the Daylight environment for DL AO render. Loving the speed but also having to cope with a blueish hue over over my floor which I am thinking is due to sky colour.
(When I use the texture environment , the bluish hue doesn't get represented on the floor)
It is a interior render so I dont know why the sky colour is coming on the floor material.
Am I missing something?
Many thanks in Advance
Hi - it is hard to tell without seeing some screenshots of the problem. But the daylight sky is blue, so it is possibly the problem.
JNDesign
thanks Paul
attached are 2 images
top image is daylight (notice the blueish hue on the floor)
2nd image is texture being white (254, 254, 254)
Interesting, I haven't seen that before. It would be good to see a screenshot of your Imager and Environment settings. Perhaps there is a large reflective surface which is reflecting the blue sky into the scene.
JNDesign
texture
texture
thanks Paul
image attached
I think the blue is coming from the reflection in the glass (which is reasonable). You can test this by setting the Reflection of the glass material to 0/black. Perhaps there is no ground - so the glass is picking up reflections from the sky from every angle?
JNDesign
thanks Paul
I will give it a go for that project
pls note that the same project , if I input the old sun model, then it doesn't put the blueish hue.
JNDesign
hi Paul
tried 0 reflection, still the same .... no change
any other ideas?
Can you pls export the scene with the blue tint to ORBX and provide a link to me, and I will take a closer look, and forward it to Otoy if needed.
JNDesign
here you go Paul
bar.ocs
(196.68 KiB) Downloaded 336 times
Return to “Autodesk Revit”
