OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
paride4331
@andrey.krivulya
Hi andrey.krivulya,
developers are fixing the issue and I testing it.
User avatar (Default)
merid888
GOOD AFTERNOON
I HAVE A PROBLEM WHEN I USE OCTANERENDER 3.06.04-4.39, THE VIEWPORT IS LIKE A MIRROR, I DON'T KNOW WHY HAPPEN THIS
SOMEONE CAN HELP ME ?
THANK YOU
ADD IMAGE
paride4331
Hi merid888,
did you try using scanline renderer mode, does your issue still happen?
mbetke
You are not using a camera and only a Top down view. This can happen. Sometimes if you zoom to much in, the scene diappears. Its a 3dsmax issue I think.
Try to set up a camera and render again. Then it should work.
PURE3D Visualisierungen
coilbook
merid888 wrote:GOOD AFTERNOON
THANK YOU
ADD IMAGE
i posted this problem 4 months ago when you using middle scroll to zoom in/out octane would just flip a viewport. It is still not fixed. It happens a lot when you work with large scenes . Version 2 never had this problem started with version 3
andrey.krivulya
paride4331 wrote:@andrey.krivulya
Hi andrey.krivulya,
Wow! Wow! Wow! Awesome! Thank you very much!!!!
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
coilbook
Hi It seems that if Disable PFlow instances is unchecked there are no pflow particles in octane viewport unless viewport % is set to something. Also particle brightness gets out of control.
when leaving a checkmark evaluation times is very slow but quantity multiplier viewport % can be left at 0 and brightness works ok.
so there is a big problem for us we have both pflow fire works and phoenix fire.
with Disable pflow mesh instances checked: PFlow is slow to load
with Disable pflow mesh instances UNchecked: phoenix fd evaluate 5-10 times slower
hopefully otoy can fix all this
Goldisart
the movement of the cube and the camera - they have one speed .... the question is what would it take what would the cube had blur
motion kub camera.zip
(30.4 KiB) Downloaded 270 times
paride4331
Hi Goldisart,
you should activate movable proxy and MB in Octane property.
attached correct scene.
motion_camera.zip
(42.64 KiB) Downloaded 275 times
Goldisart
Return to “Releases”
