Invisible Outer Walls
Is it possible to recreate this effect in Octane? I've tried using a mix material with the side node and a transparent outer material, but the walls just turn black. I'm primarily trying to create just the invisible walls, not the fading in based on normal part.
- rotating-room-shader.gif (157.7 KiB) Viewed 2697 times
- rotating-room.gif (158.75 KiB) Viewed 2697 times
Hi neasy,
base80 example?
Anyway, here is the example scene file: And here is with a Fallof node instead of the black node in the mix terxture: Happy Rendering,
caio beppe
base80 example?
caio beppe
