OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
solomonfl
paride4331 wrote:
solomonfl wrote:
solomonfl wrote:This build is causing my 3DS Max 2018 to crash.
I have attached the error I get right before it crashes.
@paride4331 is this build compatible with 3DS Max 2018?
@solomonfl
Yes It is.
I sent this crash issue to developers this morning
Hi Paride, thanks. Any idea when this will be fixed? I still can't use octane with 3DS Max 2018
paride4331
Hi solomonfl,
i am using 3dsMax 2018 for a long time and i did not encounter issues either with Maxwell or Pascal GPUs.
Another user experiences issues with 3dsMax 2018; he owns 4 x 1080Ti and 3dsMax crashes using Youtube.
What about your hardware and software configuration?
When does the issue happen in your case?
solomonfl
paride4331 wrote:Hi solomonfl,
I have 2x 1080 cards. The crash happens right away when I start Max 2018 after I install the octane plugin. When I remove the octane plugin, Max 2018 works fine.
coilbook
HI Paridie
Can you looks at this 3ds max file for fireworks (attached here). If you go to frame 800 and open viewport it takes forever to open but it is only using 0.5 GB of vram. is it a bug?
Also all these firework facing planes are they copies or instances?
Thank you!
fireworks.zip
(45.04 KiB) Downloaded 258 times
paride4331
@coilbook
Hi coilbook,
try to uncheck as in screenshot.
justix
I have a problem with the Lock Camera on my Max 2016, anyone? It switch views despite the camera is set to Lock
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
paride4331
Hi Justix,
no issue found here, testing with a previous 4.39 camera, a new 4.39 camera or a 3dsMax camera.
Trying to merge the scene into a new file?
coilbook
paride4331 wrote:@coilbook
Hi coilbook,
hi then it makes evaluation time 5 times slower. I guess otoy have mot fixed this bug yet ?
coilbook
Hi Paridie
here is a follow up file for smoke fuel where fuel now is non renderable.
if you can simulate 10-20 frame and open viewport you will see smoke works and fuel does not
Thank you
smoke fuel.zip
(35.38 KiB) Downloaded 283 times
paride4331
Hi coilbook,
5 time slower??
are you sure you have no issues around Hardware Configuration or paging system?
the workflow is very fast and does not have any issue unchecked pflow option (video attached).
test-video.rar
(1.18 MiB) Downloaded 273 times
Return to “Releases”
