Hi Paride, thanks. Any idea when this will be fixed? I still can't use octane with 3DS Max 2018paride4331 wrote:@solomonflsolomonfl wrote:@paride4331 is this build compatible with 3DS Max 2018?solomonfl wrote:This build is causing my 3DS Max 2018 to crash.
I have attached the error I get right before it crashes.
Yes It is.
I sent this crash issue to developers this morning
OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
- paride4331
Hi solomonfl,
i am using 3dsMax 2018 for a long time and i did not encounter issues either with Maxwell or Pascal GPUs.
Another user experiences issues with 3dsMax 2018; he owns 4 x 1080Ti and 3dsMax crashes using Youtube.
What about your hardware and software configuration?
When does the issue happen in your case?
I have 2x 1080 cards. The crash happens right away when I start Max 2018 after I install the octane plugin. When I remove the octane plugin, Max 2018 works fine.paride4331 wrote:Hi solomonfl,
HI Paridie
Can you looks at this 3ds max file for fireworks (attached here). If you go to frame 800 and open viewport it takes forever to open but it is only using 0.5 GB of vram. is it a bug?
Also all these firework facing planes are they copies or instances?
Thank you!
Thank you!
- fireworks.zip
- (45.04 KiB) Downloaded 257 times
- paride4331
- paride4331
Hi Justix,
no issue found here, testing with a previous 4.39 camera, a new 4.39 camera or a 3dsMax camera.
Trying to merge the scene into a new file?
Hi Paridie
here is a follow up file for smoke fuel where fuel now is non renderable.
if you can simulate 10-20 frame and open viewport you will see smoke works and fuel does not
Thank you
Thank you
- smoke fuel.zip
- (35.38 KiB) Downloaded 282 times
- paride4331
Hi coilbook,
5 time slower??
are you sure you have no issues around Hardware Configuration or paging system?
the workflow is very fast and does not have any issue unchecked pflow option (video attached).
5 time slower??
- test-video.rar
- (1.18 MiB) Downloaded 272 times
