When I use an Octane tag with X-Particles and set it to render sphere it appears in live viewer but not render.
Any idea why?
Particle rendering Octane tag
- alexchopjian
My guess is that the sphere in the hierarchy has the two red lights indicating it is hidden from both viewport and render. Try unchecking those lights, and moving the sphere out of view of the camera if it is in the way.
If 'perfect sphere' is checked in attributes of sphere object, uncheck it. Octane is unable to render perfect sphere in PV.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Thanks for the suggestions guys but neither of those worked unfortunately.
Scene attached for reference.
- XP_Octane.zip
- (43.7 KiB) Downloaded 268 times
Have you tried in particles somethings else of unvisible objects as your sphere?
I don't understand what's the problem with your file. For me it works fine, i have orange spheres in the PV. I've just pushed render in PV...animatter wrote:Thanks for the suggestions guys but neither of those worked unfortunately.
It's working here too. Cinema up to date? XP up to date?
C4D 2025 | Win10
Try to add render passes and see if this solves it, I had also a black image in the PV and after adding render passes it magically appeared.
WIN 10 64bit | Asus X99 Delux USB 3.1 | i7-5830K 3.5 Ghz | 32 GB RAM |1200 W PSU | 512 GB SSD |
2 x PNY - GTX 980 TI
1 x PNY - GTX 1070
C4D 17.55 | Octane 3.06.2 | GeForce Driver 378.49
1 x PNY - GTX 1070
