C4d Octane v3 and the Shadow Pass
johfisch
Hello, I use the Octane Plugin for C4d since two Months. Now i know the Basics and I want to compose something with octane but I cant find the normal shadow pass. I downloadet the v2 Plugin and there is the pass but when I use v2 my my whole project get messed up. Under Render Layer are only the Black shadows. colored shadows and reflectons channel.
niestudio
Have you read over the manual page for render layer?
https://docs.otoy.com/Cinema4DH/C4DPlug ... Passes.htm
video turorial here too https://vimeo.com/119848103
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
johfisch
Yes, in each tutorial they have a normal shadow pass. But I have none.
Hi johfisch,
yes correct, it seems that the c4doctane plugin has skipped that pass from 3.06, probably because a new general Shadow pass has been added in the Beauty passes.
You need to roll back to 3.05.3 if you absolutely need that pass:
Anyway, there is not any particular difference between the Shadow and Black Shadow pass in Render Layer. The only difference is that the Shadow pass need to be multiplied, while the Black Shadow pass works immediately since the shadows are masked by alpha channel.
ciao beppe
johfisch
Thank you very much. I have tryed to use the Black shadow pass but I dont know how to export it with the Alpha channel. When I try to export it I get only a black picture without an Alpha channel.
Hi johfisch,
did you enable the Alpha channel option in the kernel settings?
Please, have a look at this other discussion with example scene:
viewtopic.php?f=30&t=62817#p321359
ciao beppe
johfisch
It works! Thank you.
