Gradient driven by locator
CarlosTena
Hi .
As the subject says, I need a gradient driven by an object... any way to do this in octane or pass the modo gradient rig to the plugin ?
Dealing with this and no info about.
Thanks in advance.
Hi - I don't think you could easily do this. I suspect you would need to bake the object value to a channel and then plug that into the Octane Gradient - but it would not be easy. If you send me a scene showing what you are trying to do, I can offer more suggestions.
CarlosTena
Hi Paul.
Thanks a lot.
Attached a very basic file with the effect I need.
Test_Gradient.zip
(12.26 KiB) Downloaded 230 times
As I have no idea about how to deal with that in Octane, it's only rigged with modo native nodes.
Thanks for providing that scene. I could not achieve the result you are looking for with a gradient, but was able to get close using an Octane Noise node.
CarlosTena
Hi Paul.
... nice trick !
Thanks for your help.
It can work for this particular scene, thanks a lot.
But it's not a general fix because I'm going to have a gradient x object near that surface.
So I really need a gradient ( or whatever procedural that can achieve the same effect ) to be driven by an object ( usually a locator )... that's a technique that I use a lot in the native render and in other 3D software.
I know that because of the "correct" nature of the engine, we lose some biased functionality found in other render solutions ( I'm talking about the Octane renderer itself, not the plugin ), but I really hope this is not going to be one of that "limitations".
I will keep investigating this until as long as my deadline allows me... but if anyone have suggestions or ideas, please don't be shy to share !
Hi - I don't think you will be able to feed a formula into a gradient - unless you bake it to a color channel.
Hesekiel2517
Hey there,
maybe you can use this "hacky" approach: I basicly connected the locators position to a gradient:
I thougth i can just do this for the x y and z axis and multiply the results. It kind of works but it's not that pretty. Btw. @Paul is it possible to feed multiple Float values into a NodeGraph? I can create multiple Inputs but there are not present in Modo.
Greetings!
Color_by_Distance.zip
(94.36 KiB) Downloaded 238 times
Hesekiel2517
Ok, i thougth about it and build another rig. This is much simpler and looks better:
(83.97 KiB) Downloaded 217 times
CarlosTena
Hey.
Thanks a lot for the answer.
I finally found some similar solution but your rig seems more sophisticated !
Return to “Foundry Modo”
