Modo 11.1 Octane VDB Problem
jtmsf
Hi :)
I read that there's a bug in the latest octane for modo plugin (3.06.1.120) from this post
viewtopic.php?f=34&t=62486&p=319335&hilit=vdb#p319335
I don't know if the issue I'm having with VDBs in Octane For Modo is related or not to that bug. I'm Uploading the images and .LXO
I downloaded these .VDBs from http://www.openvdb.org/download/
And did a setup in MODO 11.1
Octane renders the "fire.VDB", but not the "bunny_cloud.vdb".
I also dd a test setup with a sphere mesh as a vdb source. Octane doesn't render it.
Are the bugs related? If not is there a fix for this problem?
Best regards
jtmsd_Joao
Windows10
MODO11.1
Octane for Modo 3.06.1.120
Octane Standalone 3.06.4
three_lxo-s.zip
lxo's with the setup
(35.3 KiB) Downloaded 256 times
Hi - I am midway through putting together the 3.07 build of the plugin, so could not do a full test, however "Teste 92_VDBFromMeshOctaneNotWorking.lxo" rendered OK for me - so it would probably render OK with the latest version of the plugin available in this forum. I will test the other files once I get further through the Octane 3.07 build.
jtmsf
HI
Thank you for the information.
I'm using Modo 11.1v1 with the latest version of Octane plugin downloaded from the forum (3.6.1.120). "Teste 92_VDBFromMeshOctaneNotWorking.lxo" doesn't work :|
I wrote in the initial post that i was using "Modo 11.1", but i'm using 11.1v1. Don't know if that could make any difference...
Thanks once again
I will have a new version of the plugin available in the next day or so - pls try with it, as it's working for me on that version.
jtmsf
Thank you Paul.
jtmsf
Hi Paul,
Downloaded and installed the test build 3.07.0.123
However now none of the examples I sent earlier are rendering, even the one that worked previously. :(
"bunny " : Still not rendering
"fire" (this one worked previously): not rendering now
"from mesh": Now i can edit the nodegraph connection on the octane override in the "mesh connected to vdb source". Previously it wasn't working. Still not rendering
jtmsf
Hi
Here's a screenshot of the fire.vdb after installing test build 3.07.0.123
Remade the scene with all the steps in Paul's video tutorial (link below), in case i was missing something.
https://www.youtube.com/watch?v=0pTMl5G5sJU
Fire VDB not working now
Octane doesn't render fire.vdb volume anymore
(the other ones, "vdb from mesh" and "bunny.vdb" still don't render)
Thanks for any help in solving this vdb problem
OctaneVDB_FireNotWorking.zip
Lxo with fire.vdb
(9.6 KiB) Downloaded 224 times
jtmsf
An update:
Inside Modo if I export "OctaneVDB_FireNotWorking.lxo" to .OCS format, and then open in octane standalone 3.06.4, it renders ok.
Screenshot from Octane Standalone
Fire.ocs
Exported from OctaneVDB_FireNotWorking.lxo
(34.08 KiB) Downloaded 244 times
jtmsf
In Modo I made a simple setup using a particle simulation as a vdb voxel source, and then connected this vdb voxel to a volume.
Octane Plugin: does not render
Modo Setup, and octane plugin not rendering
Then I exported the scene to a .OCS and opened it in Octane Standalone: rendered ok
StandaloneOctane_OCS from modo. Renders OK
I don't know if this helps finding the problem, but i'm posting anyway
VDBfromParticles.zip
.lxo file
(3.79 MiB) Downloaded 250 times
ModoExport_VDBfromParticle.ocs
.OCS exported from MODO
(34.05 KiB) Downloaded 240 times
These issues appear to be a problem with Octane 3.07 test 4. I have reported the issue to Otoy.
Return to “Foundry Modo”
