Hi, I was wondering if it is possible yet to get motion blur on alembic objects imported from Houdini? I saw an old thread about this but thought there might be some news regarding this.
Cheers
							Motion blur on Alembic from Houdini
Why not? It's just a geometry at the end.Chrmez wrote:Hi, I was wondering if it is possible yet to get motion blur on alembic objects imported from Houdini? I saw an old thread about this but thought there might be some news regarding this.
Cheers
Ahmet but if u have varying amount of geometry like in a water sim? i think R19 will introduce the same vertex maps solution for alembic as realflowaoktar wrote:Why not? It's just a geometry at the end.Chrmez wrote:Hi, I was wondering if it is possible yet to get motion blur on alembic objects imported from Houdini? I saw an old thread about this but thought there might be some news regarding this.
Cheers
In this case, normal workflow will not be enough. You'll need to assign vertex speeds by vertexmap tags like we do in Realflow meshes.Studio21 wrote: Ahmet but if u have varying amount of geometry like in a water sim? i think R19 will introduce the same vertex maps solution for alembic as realflow
Ah I'll have a look at that. I've just tried regular object tags but it did nothing.aoktar wrote:In this case, normal workflow will not be enough. You'll need to assign vertex speeds by vertexmap tags like we do in Realflow meshes.Studio21 wrote: Ahmet but if u have varying amount of geometry like in a water sim? i think R19 will introduce the same vertex maps solution for alembic as realflow
C4D R18 / C4D R19
AMD Ryzen Threadripper 1950X — MSI X399 Gaming Pro Carbon
MSI 1080 Ti FE — 2 x PALIT 980 Ti Super Jetstream
Corsair AXi 1500W — Corsair Vengence 32GB 3000MHz LED White
