Cloud Rig
Houdini Integrated Plugin
crackfox
hi there,
i am having fun playing around with houdini and trying to figure out limitations of octane.
i managed to create an cloud object and it renders well, however cloud system rig does not show.
i tried to add octane params to it but no luck.
is there i way i can make octane see the cloud rig system?
best.
juanjgon
The cloud rig objects are conventional Houdini volume objects, so they can be rendered as Octane volumes if you enable this option adding the Octane OBJ spare parameters.
crackfox
hi juan and thank you again.
sorry, i was actually referring to the skyrig system.
i tried to convert it into volume but nothing happens.
screenshot below. hope its possible to render.
simple/single clouds work indeed finde.
juanjgon
Hmm, in any case, the volumes should be Houdini volume objects that can be rendered by the Octane plugin. Not the lights, or the environment, but the volumes should work.
If you want to share the scene, I can take a look at it here.
crackfox
ofcourse, and thank you for the attention on friday.
file attached.
untitled.zip
(124.5 KiB) Downloaded 238 times
juanjgon
Sorry, I'm on a short break this week. I'll take a look at it next Monday.
Thanks for your patience,
crackfox
very kind of you to drop a note, thanks.
i hope you enjoy the well deserved break.
cheers,
juanjgon
The problem is that somehow in your scene the render output SOP is not connected to the volume VOP, so nothing is rendered. You need to connect it like you can see in the attached scene. Also be sure to disable the OpenVDB file option in the OBJ spare parameters.
Return to “Houdini”
