Rendering background image
alfabruce
Hi everyone,
Im trying to match up the colour, lighting, perspective etc of a spaceship sitting infront of a photography I took and are using as a background image.
I am using either
viewport properties/wallpaper and loading the photo there or
Display options/viewport settings and loading it there. Not sure which is better or maybe they are the same??
I am able to successfully export the image using the alpha image transparency and put it together in photoshop.
However, I am finding it very hard to make sure the colour and lighting and perspective etc match up.
Its a very long winded process to take the image out into photoshop, load it and copy paste ect into the image, then scale and review it to realise that there is not enough orange from the sun etc to match the background.
I would love to be able to do a rendering in the OCTANE RENDER VIEWPORT that show the background image behind it.
There is a thread here
viewtopic.php?f=30&t=45810
with several users expressing the same desire in another plugin. This thread asks about enabling the KEEP ENVIRONMENT in the KERNEL settings. I have tried this but only get a black background, no photos.
Is there something Im doing wrong here. Its this even possible in the RHINO version? Should I be using a render pass with ENVIRONMENT or INCLUDE ENVIRONMENT enabled?
I will still put the final image together in Photoshop but need to use the 'rough' preview in the octane render viewport to help me get it looking correct.
Cheers
Tim
Hi - this is a limitation with Octane - in that it does not same the background image with the PNG. However it is worth considering that if you use a background plate, the lighting is never going to match the rendered geometry, so it is not going to be as realistic as if you took a 360 degree lat/long shot of the beach. To do exact matched of the background plate, have a look at http://photomatch.phantomtechnology.nl/.
alfabruce
Hi Paul,
Is there no way of combining these in a draft image type of thing, i know it would be a huge plus for the type of thing i am doing. The other tread for the other plugin removed it and then added it back in again as lots of people seem to find it very useful.
Cheers
Tim
It's not something that could be easily implemented in the Rhino plugin Tim. I am hoping the upcoming Octane Image API enhancement will allow for the background image to be composited into the render though, so stay tuned....
formatio
Hey
I did this image using background image and then combining everything in photoshop with couple of touches here and there.
alfabruce
Thats looks good Formatio. Im quite happywith the results I get using the current workflow, its just the time and going back and forth that I find a little frustrating.
Paul, that tweak sounds promising. I look forward to seeing it.
Cheers
Tim
Return to “Rhinoceros 3D”
