Render failed
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
paride4331
Hi coilbook,
i tested your scene;
1200x800pxls path tracing 2000 smpx on Laptop 16Gb Gtx1070:
Render mode:
frame 1202 geometry voxel > 3.08 min
frame 1202 render time 2.39 min
frame 1203 geometry voxel > 1.19 min
frame 1203 render time > 2.37 min
Render Viewport:
frame 1202 geometry voxel > 3.36 min
frame 1202 render time > 3.24 min
I sent a pm for more details.
coilbook
paride4331 wrote:Hi coilbook,
Render mode:
Render Viewport:
thank you
if they could render around 200 frames of flying camera at 1080p pathtracing that would be nice to know if they have cuda errors
paride4331
Hi coilbook,
As I wrote in PM,
about CUDA error test, developers asked to make this test:
you should have to copy the file "octane_log_flags.txt" (attacched) in Octane Standalone main root directory
remember to enable the permissions to write Octane folder.
e.g. OctaneSA select folder> Rightmouseclick> properties> security> ...
Then, restart and generated the issue (using Octane SA).
after error issue, create "Octane_log.txt" to send me: "windows > create log window", and save it.
Use attached files please, I made some mod inside them.
Regard
(120 Bytes) Downloaded 247 times
coilbook
I will. I even get render failed while switching from AO to diffuse/pathracing while viewport is open
paride4331
On August 11 I asked you to do a test for developers:
viewtopic.php?f=81&t=62496&p=319652#p319765
Where is it?
Developers asked it to solve your issue, do not share that is losing time to solve it.
Return to “Bug Reports”
