Whenever I try to use both a normal map and a displacement map on the same material, it glitches out and looks weird. If I use just the normal map, it looks fine. If I use just the displacement map, it looks fine. Am I doing something wrong?
I need both because the normal map is providing fine detail and the displacement map is a more large scale surface adjustment.
Displacement + Normal maps?
- paride4331
Hi wrenthereaper,
normal+displ work well; attachments and screenshots for you to test.
- 02.zip
- (7.64 MiB) Downloaded 251 times
- wrenthereaper
- paride4331
Hi wrenthereaper,
here test scene 3dsMax 2015 made with Octane Render 3dsMax plugin 4.38
Let me hear from you.
- 02.zip
- (7.62 MiB) Downloaded 204 times
- wrenthereaper
Thanks for uploading that. So initially, I couldn't see the polygon lines in your project file. However, when I scaled up the layer, or reduced the displacement amount, the polygon lines began to show again. I've uploaded images of what I'm talking about. Interestingly, when I increased the number of subdivisions on the plane, the problem got worse.
The first image is the first image after opening the project file.
The second image is after reducing the displacement amount but not scale.
The third image is after increasing plane subdivisions.
Each quad is being split, and either the smoothing is glitching out or the UV is because the textures no longer align at each polygon intersection.
- paride4331
HI wrenthereaper,
What about Octane 3dsMax plugin are you using, version?
- wrenthereaper
I'm using 3dsmax 2015 and Octane 3.03.3 - 4.16
- wrenthereaper
- paride4331
Hi wrenthereaper,
this issue was fixed many 3dsMax plugin versions ago;
Download the latest version 4.38 3.06.4:
https://render.otoy.com/customerdownloa ... -_4.38.exe
here new features of 3.06:
viewtopic.php?f=24&t=60014
