Camera offset does not match
C. RAM Capacity (i.e. 6 GB)
When using camera offset the Editor view and LV do not match (LV often has too much offset compared to Cinema's editor)
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Sample scene please?
when I have time...
I had some time:
http://imgur.com/a/t4mnU
Here's a gallery (I made the borders bright green and turned the grid off, so it's more obvious.
I'm on the latest standalone (3.03) and as of writing, the most current c4d plugin (3.03.3 R1).
Cinema 4D R17 .48 (not the very latest patch).
I've attached the file.
To me as far as I was playing with the film offset in the camera settings produced this result.
This effect (from my limited testing) only occurs with the Film Offset on Y and is not present with horizontal (X) offset.
Using the lens shift doesn't produce this effects simply because the effect is completely ignored by the editor view.
Hope this helps.
Hope this helps.
- CameraOffset.zip
- Camera offset demo.
- (91.11 KiB) Downloaded 304 times
Well. Understood why it's diffent. Actually it's not a wrong calculation because offset values are correct. But Y size of rendering is bigger than viewport. It requires a revision on LV with unlocked resolution.
Reviving this issue as its causing huge problems on our current print prodution and its still not addressed (thanks dotjack for posting the example!)
I don't understand the reply Ahmet. It doesn't match the LV nor the Picture viewer. It doesn't work properly using the offset in the Octane camera tag either. In fact in that case the LV looks right but the picture viewer is wrong!
Thing is using camera offset throws the render regions out as well.
Sending picture will help always. Could you please figure it by images+scenes what we are talking about exactly as my picture?sdanaher wrote:Reviving this issue as its causing huge problems on our current print prodution and its still not addressed (thanks dotjack for posting the example!)
the other guy already did, it showed the issue and the values used.
try offsetting vertically by at least 30%
Sorry attached wrong picture. I'm answering a lot people at same time. Here's correct one.sdanaher wrote:Very cryptic... I have no idea what this pic is supposed to be.
Is this any clearer?
