background animated like C4D
inesalpha
Hi ! two years later, I come with I think the same problem ^^
I would like to have my animated background, which is a video footage, in octane render, so I can check if my compositing is right.
I have a background object, an octane texture with image texture in diffuse channel, jpg sequence, editor preview checked...
Still Octane shows only the first image of my sequence.
Thank you so much for your help !
inesalpha wrote:Hi ! two years later, I come with I think the same problem ^^
Have you set range values in animation tab of imagetexture?
inesalpha
Thank u aoktar
Yes I set the range values :(
Could my range values be a problem if it doesn't begin by zero ?
my images finish like _01632 (first image) to _01957 (last image)
Thanks for your help !
inesalpha wrote:Thank u aoktar
Try with standard material and bitmap not octane textures.
inesalpha
I was going to tell you "Yes I already tried and it did not work either " which I did, I tried again just in case... It seems to work (-____-)
Thank you very much and sorry for the inconvenience because of the stupid question :(
inesalpha
Actually it's not working when I render... don't know why :-/ it's ok because I'll need compositing in AE but still, why doesn't it work ? :-/
inesalpha wrote:Actually it's not working when I render... don't know why :-/ it's ok because I'll need compositing in AE but still, why doesn't it work ? :-/
Explanation is in the picture.
inesalpha
that box is checked in my settings :-/
It's ok I don't need the background to be animated in my render ^^
But still it's annoying not to know why ! It's again not working in the preview (-___-') and I changed nothing since I told u it finally worked :-/
Thanks anyway !
inesalpha wrote:that box is checked in my settings :-/
Thanks anyway !
Propably some overlook on your settings. It is working always like this. Good luck!
Return to “OctaneVR Questions & Discussion”
