Failed to Deactivate all licenses use on this computer
Noctivagant
Hello,
I checked the forums and help.otoy but couldn't really find an answer.
I'm using Octane on two computers one for editing the scenes other one is a render node. When I finish editing a scene, deactivate my license from settings and reactive on render node. Today when I tried to quit I got this message
I went to my account on the site and deactivated from licenses,then activate on my render node. After rendering I wanted to deactivate on the node and reactivate on my editing PC and here I get this message
I updated my Standalone and the Plugin but on both computers I get these same messages separately, If you could help I'd appreciate it.
Thank you
Hi Noctivagant,
I can confirm that there is an issue with the manual deactivation.
Please, close all the application, and check in Task manager if there is not another process active that is blocking the deactivation.
In theory, v3.06.2 should be correctly deactivated on exit.
ciao beppe
MarioVisuals
I have exactly same problem Cinema R18, Win 10 and MacOSX 10.11.6.
Windows 10 Pro 64-bit / Intel Xeon E5 v3 @ 2.40GHz x 2 / 64 GB RAM / Z10PE-D8 WS / 3 x EVGA GTX 980Ti / C4D R17 / X-Particles 3.5 / Octane 3
in theory, v3.06.2 should deactivate on exit, at least here is working as expected, I cannot manually deactivate, but the licenses are correctly deactivated on exit.
Did you check at you OctaneLive page if they are still active or not?
https://render.otoy.com/account/octanelive.php
ciao beppe
MarioVisuals
Yes I did and eventually I've used online Unlock to free the licence.
I did full reset on both computers before, that didn't work either.
I'm rendering a job at the moment, will do some more tests tomorrow.
Noctivagant
bepeg4d wrote:Hi Noctivagant,
ciao beppe
v3.06.2 here, no it doesn't deactivate I also checked octanelive it shows the last computer i signed in with (which I cannot sign-out)
I'm only experiencing this problem since the last two days btw, never happened before.
mojave
We spotted what is causing this issue, we will push an update to our server that will fix this in the next few hours.
Apologies for the inconvenience and thanks for reporting.
Thanks mojave, the issue has been successfully solved, and now the manual deactivation works as expected.
Please, always prefer the manual deactivation instead of the web deactivation, that must to be used only if the manual deactivation is not possible.
Happy Rendering,
ciao beppe
MarioVisuals
It's working fine today!
