OctaneRender® for 3ds max® v3.06.4 - 4.36 [OBSOLETE]
paride4331
Hi coilbook,
I did some tests about your issues: they happen randomly and are probably similar to issues about IDs and WSMs that we wrote earlier days.
I will add this to the alert for developers. Refresh issues in Octane render view could be acceptable using volumes and particles, by their nature, but not in Render.
coilbook
paride4331 wrote:Hi coilbook,
Great! Thank you
Elvissuperstar007
Need an automatic interactive button, Only for 3ds max it is necessary to tick the movable proxy, for interactive. New users do not know this
paride4331
Hi Elvissuperstar007,
C4D has movable proxy presets, maybe developers could put in 3dsMax too;
Then inexperienced users all end up using "all movable proxy" but I think that's not a good way to use Octane Render at best.
coilbook
hi
why is material editor is so laggy. even when we use second card for octane viewport and main one is not used material editor is so slow
paride4331
HI coilbook,
Could you take a look at this:
viewtopic.php?f=81&t=55962#p316842
You could also clean your material editor slots from unused materials and set manual update material preview.
coilbook
why if dummy is accidentally set to movable proxy and motion blur octane viewport is stuck at 1
thanks
coilbook
paride4331 wrote:HI coilbook,
thank you but it still seems it was faster in version 2
acc24ex
anyone having some gamma issues while saving - just keeps on looking darker than on render..
paride4331
Hi acc24ex,
I did some tests all seem to work.
On what occasions happens to you?
Return to “Releases”
