36/36 ray depth is not enough!
LightwaveGuru
hi juanjo,
i think 36/36 ray depth for the PT Kernel is from case to case not enough! if you build a complex SSS shader with a second (or more) material layers with light transmission options i have the feeling thats not enough...
is it possible to enlarge the depth up to ...i dont no...96 or 128? :)
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
juanjgon
You can type any number in the numeric field. In fact, in Standalone you can set at least 2048 rays, so I suppose that Octane supports it ;)
Great render, BTW!
LightwaveGuru
juanjgon wrote:Hi,
Great render, BTW!
oh my gosh i am so stupid! i never test it to type it in :) ok...stay tuned for the next renders....i think it would be much better with more depth :)
snip lwguru
LightwaveGuru
64/64 depth PT
snip lwguru
Draydin_r
I would love to see the result, but it seems the image won't show up/is locked. Could you re post?
Intel Core i7 CPU 6850K @ 3.60GHz 128.0 GB Ram / Win 10 64 bit / 1x GeForce RTX 3080
3dworks
Draydin_r wrote:I would love to see the result, but it seems the image won't show up/is locked. Could you re post?
yes please, also your website link is not working. :mrgreen:
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
LightwaveGuru
KVNOODLES
juanjgon wrote:Hi,
Great render, BTW!
Hi Juan,
It seems we can put up to 2048 shading Depth samples in PathTracing Kernel right ? But is it the same rules or limitations for Direct Lighting and PMC Kernels ?
Thanks.
juanjgon
Check the limits in the Standalone. The PMC kernel has the same limits, but the in the direct lighting kernel the limits are lower. I suppose that large values make no sense. I suppose that I should update the plugin to have these also these limits in the sliders.
KVNOODLES
Great ! Thank you Juan.
Return to “Lightwave 3D”
