OctaneRender 3 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
garand3d
I could not reproduce this issue with V7. I can you show me the DAZStudio shader for EyeMoisture? And can also send a screenshot after you click Nodegraph Editor for the EyeMoisture material pls?
Did you try to reproduce it using the new test release?
I've just updated to test build 3.6.4.34 and I can no longer reproduce this issue with V7 or any other Genesis 3 characters I have... it seems to have been fixed, at least for G3 characters. EyeMoisture is correctly (I presume) converted to Specular now instead of Glossy as in the previous OcDS build where I first encountered this issue.
However allow me to use the same bottle that still has the issue persisting, it should be analogous to the EyeMoisture. I think it's safe to assume that there are other figures and props that are still affected by the issue, I will report it if I find it.
Sorry, should've shown this earlier. As you can see Roughness and Opacity are connected to the same Greyscale node. The same thing that used to happen to the EyeMoisture
Not sure how you want me to show you the DAZStudio Shader, so here is a screen showing the Gloss and Roughness related settings. If you want the shader preset file pls let me know, I will PM it to you.
Win 10 Pro 64bit | 2 x ASUS GTX TITAN BLACK, 6GB GDDR5 | Intel Core i7 3770K, 3.50 GHz | 32 GB RAM
MSI GT83VR SLI 7RF | Win 10 Home | 32 GB RAM
DAZ Studio Pro 4.10.0.123 | OR S.A. V3.01.1b | OCDS V3.8.2.39 | GeForce Driver 398.36
Can you post screenshots showing the rest of the shader pls?
bblogoss
I think there is a problem with G8F default material conversion :o
latest plugin version 3.6.5.33 of june 16
TRRazor
It's not a conversion issue, it's the maps DAZ3D uses in their new skin shader. They take a heavily yellow-filtered diffuse and blend it with a red-blue SSS map to achieve a half-way realistic skin color. Unfortunately - at least at this point, this blending isn't implemented in the standard conversion yet.
Our upcoming RedSpec SSS shader update for G8F will actually fix this, you can see the result here: http://trrazor.deviantart.com/art/Victo ... -686824238 and here http://trrazor.deviantart.com/art/RedSp ... -686621863.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
It also looks like the bump is too high. I would be interested to hear others experiences. You can change the bump conversion factor in the Preferences tab.
garand3d
Certainly, here they are.
#2
#3
#3
#4
#4
TRRazor
And this would be Victoria 8's shader
garand3d - I cannot reproduce the problem you are having if I use a material as per your screenshots. Are you able to send me a scene with that material used on a cube primitive pls?
garand3d
Paul - I just PM'ed you the cube.
Cheers
I have updated the installer at the top of this thread with:
3.6.4.34
- Compiled with Octane 3.06.4
- Fixed issue where the Genesis 8 figure EyeMoisture surface was rendering with a clay material
- Fixed issue where the plugin would stop saving Preferences settings. You will need to delete C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb in order for this change to be applied
- Fixed issue where the Camera Bokeh controls were not live-updating the Octane camera
- Fixed issue where Perspective Correction and Spherical Distortion were not being set correctly when opening the Viewport
Return to “DAZ Studio”
