Morphs not rendering?
Builtdown
I have an object with a morph applied to it.
It renders fine.
I then duplicate the morphing object few times, but only the first is seen when rendered.
Why?
LightwaveGuru
Builtdown wrote:Hi,
It renders fine.
Why?
its a lw bug. the duplicate objects need a individual name. than it would work. so make some copys from the object in lw modeler and replace that individual named objects in the scene....
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
Builtdown
Thanks, that helped!
juanjgon
The problem can be also related to the "instance LW clones" feature. With this option enabled (you have it in the render target root node options panel), all the LW clones are extracted as Octane instances, and all the instances must share the same base mesh. Probably disabling this option your scene could work fine without renaming the objects.
promity
Another method. Turn off 'Instance LW clones'.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Return to “Lightwave 3D”
