Octane for Softimage 3.0x
- Elvissuperstar007
- Contact:
Do not forget to add a converter Redshift to Octane
There wasn´t a plan to do it, but i can translate an existing Redshift shader to Octane, if i know which parameters the Redshift shaders have.Elvissuperstar007 wrote:Do not forget to add a converter Redshift to Octane
It´s also on you to tell me which Redshift parameters should drive which Octane shaders like:
Redshift diffuse color should drive Octane diffuse color and so on...
Here is also a render test from a Houdini VDB inside Softimage.
https://vimeo.com/219216039
http://vimeo.com/user2509578
Possibility to use surface and volume shaders on one material.
The plugin will automatically assign the right material to the mesh/pointcloud.
And at the best, the plugin is comming soon after a update to 3.06.2...
face
face
- wireframex
Hey Face
Any beta release soon ?
Phil
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
- Elvissuperstar007
- Contact:
Programmer is just a sadist)))))) I hope we'll see sometime beta!
Yes, soon...wireframex wrote:Hey Face
Phil
Elvissuperstar007, i wait also for an answer from you about the redshift converter.Elvissuperstar007 wrote:Programmer is just a sadist)))))) I hope we'll see sometime beta!
face
Added support for export passes per frame, so you can open each frame in Octane standalone.
- export.gif (7.73 KiB) Viewed 10227 times
The last thing to code is the object layer for volumes/strands which should be finished in around a hour.
Then i must make the documentation
face
face
- Elvissuperstar007
- Contact:
- wireframex
Is it real ??
Edit : Can't wait to test it
Main Computer:
