Octane for Softimage 3.0x
Elvissuperstar007
Do not forget to add a converter Redshift to Octane
face
Elvissuperstar007 wrote:Do not forget to add a converter Redshift to Octane
There wasn´t a plan to do it, but i can translate an existing Redshift shader to Octane, if i know which parameters the Redshift shaders have.
It´s also on you to tell me which Redshift parameters should drive which Octane shaders like:
Redshift diffuse color should drive Octane diffuse color and so on...
Here is also a render test from a Houdini VDB inside Softimage.
https://vimeo.com/219216039
http://vimeo.com/user2509578
face
Possibility to use surface and volume shaders on one material.
The plugin will automatically assign the right material to the mesh/pointcloud.
And at the best, the plugin is comming soon after a update to 3.06.2...
face
wireframex
Hey Face
Any beta release soon ?
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
Elvissuperstar007
Programmer is just a sadist)))))) I hope we'll see sometime beta!
face
wireframex wrote:Hey Face
Phil
Yes, soon...
Elvissuperstar007 wrote:Programmer is just a sadist)))))) I hope we'll see sometime beta!
Elvissuperstar007, i wait also for an answer from you about the redshift converter.
face
face
Added support for export passes per frame, so you can open each frame in Octane standalone.
face
The last thing to code is the object layer for volumes/strands which should be finished in around a hour.
Then i must make the documentation :roll:
face
Elvissuperstar007
!!!!))))) :twisted: :mrgreen:
wireframex
Is it real ?? :shock:
:mrgreen:
Edit : Can't wait to test it :)
Main Computer:
Return to “Autodesk Softimage XSI”
