OctaneRender® for 3ds max® v3.06 - 4.33 [OBSOLETE]
- Elvissuperstar007
- Contact:
PMC test Pay attention to speed
- paride4331
Hi Elvissuperstar007,
Here for you.
Here for you.
- test_octane2.zip
- (6.71 MiB) Downloaded 296 times
- paride4331
- Elvissuperstar007
- Contact:
Thank you!
- paride4331
@perro_abombao
Hi perro_abombao,
I tested your issue but did not crash, everything seems to work fine.
Could you kindly share your scene (in pm if you want) that crash and a screenshot with your batch Render setting?
Hi perro_abombao,
- paride4331
Hi perro_abombao,
I tested your shared file, your issue happens as you said.
I did a different workflow and everything worked.
I'll send your issue to developers.
Meanwhile you can use this workflow to use Render Element and batch render.
Thanks for reporting.
- paride4331
Hi Elvissuperstar007,Tema wrote:Nothing has changed, the speed is less... One and the same scene, but works differently in new versions of octane.
I updated the video card driver. It was even worse.
Could you kindly share your scene about PMC report?
My test seems to show exactly the opposite about yours:
viewtopic.php?f=80&t=60992&start=120#p315414
Here's the scene that was on the test:paride4331 wrote:Hi Elvissuperstar007,Tema wrote:Nothing has changed, the speed is less... One and the same scene, but works differently in new versions of octane.
https://yadi.sk/d/1oVCwnzc3JwCS4
- paride4331
HI Elvissuperstar007,
I made PMC test with your scene,
It seems to confirm my previous test.
I honestly do not know what to say.
You could make a clean uninstall of Nvidia drivers before installing latest Nvidia drivers:
http://www.guru3d.com/files-details/dis ... nload.html
And do not install any CUDA toolkit.
