HDRI doesn't update
fabrizio_s
I have a little problem with hdri.
When I change the rotation (Octane Sttings - Environment - Projection - Rotation), HDRI doesn't update the effect on the render and I have to modify the Gamma of HDRI to see the change.
Did somebody have the same problem?
Fabrizio
Which release number of the plugin are you using pls?
Can you post a screenshot of the Environment Image node tree settings so I can see the projection that is being used?
fabrizio_s
Hi Paul
the release is 3.6.5.82.VR
bye
Hi - there was a fix in Octane 3.06.1 for this problem. So pls try with 3.6.1.83.VR.
fabrizio_s
Hi Paul,
but where can I download this version?
Otoy have not posted the latest version yet - but you can download it from here -> https://render.otoy.com/customerdownloa ... IPTION.rhi
fabrizio_s
ok, thanks.
I downloaded plugin from your link because on my download area I can't see this version
bye
formatio
This also happens in standalone, is there a fix for standalone for download too?
Regards,
Mac
Which version of Octane Standalone are you running pls?
formatio
Latest - 3.06.4
But I think this happens not every time - I think that if I create some rig with nodes to control the hdr map - than the new position/rotation only updates after changing its gamma value. The viewport refreshes itself but map is not rotated every time i touch the rotation slider.
If I don't create any additional nodes and rotate the map in the environment then it works ok.
Return to “Rhinoceros 3D”
